The upper (self-cleaning) oven is locked. Tried all the "reset" ideas I found online but no help though I did hear some ticking after resetting the breaker to the oven. Was able to push latch aside to get door open and want to check locking mechanism but cannot tell from exploded views I have found if I will have access to the lock motor, wiring, and switch assembly by removing the control panel, though it seems that would be the only way to get it. Also it's not clear if I must remove all the screws on both the top and bottom of the control panel in order to remove it.
