Oven and none of burners will heat up unless the left front element is turned on and then they all seem to work okay. Also the fan barely runs unless the left front element is on and then it runs at normal speed.
Prior to this the temp. on the left rear element didn't regulate very well and the indicator light on left part of cook top "flickered" instead of coming on and off.
:confused: Any suggestions?
