I have a WDT710PAYM4 whirlpool dishwasher. I've replaced the heating element and thermostat to try and get the heated drying to work again, but it's not working at curent. I've heard that the way to finish this repair is to use the dishwasher's reset code, but all my searching has only found instructions for other models that don't work on mine. "Should I also be looking at something else? A fuse, or connection issue, or mechanical reset? The wash works fine, so the only issue is the heated dry cycle, which was why we started with the element and thermostat."
