Hello! I've had nothing but trouble with my Samsung Dishwasher since we've purchased it. I had some warranty work done before the year was up, but it didn't help.
Problem: There are food particles on dishes after running. They are often on top of cups and upside down bowls. Glasses have small particles on them.
I've replaced the A/s Assy-Case BRAKE DD82-01111a...it was clogged with particles
I had water spitting out of the Vent. I took that apart and it was full of food particles that was keeping it from sealing right.
When I take off the whole top sprayer arm assembly, there are food particles gunked up in the back of it in between the arm and the back of the dishwasher.
I have made sure we run hot water.
I use extra dishwasher detergent on the bottom before running.
I have enough water pressure (I Believe it's right at the lowest suggested level).
I use the Auto cycle and have enough dryer liquid.
I run a vinegar cycle once a week to clean it.
All this and it still gunks up with food particles.
Anything else to try?
Thanks!
