My Whirlpool model #WDF510PAYSA will not heat the water or dry the dishes. The light that indicates the dry cycle in selected works and is on. I have replaced the heating element, tested it prior to installing for proper resistance. The washer still does not heat. What other parts are associated with heat control that I can check and replace?
