I've been through all the usual checks.. this washer is not filling correctly, or driving the rotors. All that seems to be left is the motor, which is expensive. Is there some way to verify motor failure before going forward? I'll add when having access to the impeller, it did not spin freely, but it did turn. I understand the fill valve may be faulty as well, but not sure how to verify that. Not clogs anywhere. Thanks for any help
