What should be the convection oven's element temperature compared to convection oven's temperature setting?
Using a laser thermometer when I set the convection oven to cook at 400 deg. F the element temperature reads around ~200 deg. F. Is this normal?
I took readings every few mins for 20 mins and the convection oven's element temperature stayed around 200 deg. F.
One time while cooking 1 lb. of hamburger another time when cooking a couple of hot dogs.
I'm trying to test a 1.2 cu. ft Samsung microwave / convection oven to make certain it's operating properly and at the right temperatures.
