WP dryer timer was not advancing and burner not coming on. Replaced high limit stat and cycling thermostat. Burner now ignites and timer advancing. But now drum will not stop spinning when door is opened and when timer advances to cool down, the household circuit breaker trips. Do these symptoms appear to be a problem with the timer?
