My freezer won't power on after a power outage. The control board lights up correctly, the inner lights are on. No heat or vibration on compressor, no fan sound just inside lights and control lights. I've unplugged it for a week now and nothing. I tested the control board like you mentioned in some other post. Pins 2 and 8 and I get 132volts across (you mentioned 120v I don't know if this is problem) I also changed the capacitor and relay and same problem.
What do you think? Thanks in anticipation.
