:eek: When I try to run my dishwasher it goes on for a minute, then stops. The 'clean' light is blinking. The manual says it is a problem with the heating unit & call service. Any ideas that I can troubleshoot?
Here is your tech sheet http://www.servicematters.com/d...0Sheet%20-%208535451.pdfCheck that the heater has continuity, should be around 20 ohms. Check that the high limit thermostat is OK, should be 0 ohms. Check that the door switch that goes to the heater is closed when the door is shut. |
THIS FORUM IS DEAD!!!!!!! |
