bhorvath7666
#1 Posted : Sunday, January 8, 2017 8:03:15 AM(UTC)
bhorvath7666
LG Model WM3470HVA
Recently noticed a small amount of water on the floor after a load is completed. I checked during a load and there wasn't any sign of a leak but a little while later I noticed a small amount of water at the back right corner. I pulled the machine out and it looks like it is coming from the rear or rear right.
I removed the rear panel and there was some water pooled up at the lower mount of the rear shock and it appeared to be leaking from the motor housing since the bottom of the housing was wet - see attached pictures.
Any guidance would be greatly appreciated.
bhorvath7666 attached the following image(s):
