dcmossop
#1 Posted : Monday, December 12, 2016 7:16:24 PM(UTC)
dcmossop
My kitchenaid stove is acting up
the highest temp the digital control panel will let me set it to is 250 degrees, yet the oven will actually warm to 425
So, if I try and turn the oven on to 350 on the digital board it defaults to 176 degrees
My electrician friend thinks it is the thermostat and pulled it out for me to replace
The oven is still working as it was without it in, so I think I have part of the problem?
The part is a little saucer like piece
The markings on the side read
9759944 A1013 F140-18F 36T22 21618
I have searched for the part online but can't find it?
Not sure which part of the numbers listed above are the part number?
Thanks for any diagnosis or direction
