PRG486EDPG/01 Thermador Bake/Convection on large oven will not ignite gas...you can hear the gas for 5-10 seconds and then a click like it is shutting off the gas...there is no ignition of the gas. I replaced the igniter...I replaced the main control boards...I checked the continuity of the ignition wire and it is fine...I even checked the temperature sensor and it is fine as well...the smaller oven works fine...the large oven works on broil fine. :( any help appreciated
