Have had assembly apart, was evidence of water in unit, crud on small computer board. Board only has 2 resistors and proximity switch, 3 wires. Yellow thru resistor to black to switch thru resistor to red. Wire brushed board, Tested fan and solenoid, both good. Reinstalled into dishwasher and still getting error. How can I test the switch? Can I run a test through the control board/panel?
