alextr
#1 Posted : Sunday, November 1, 2009 5:32:01 PM(UTC)
alextr
All the lights around the control dial will bink twice every couple of minutes. When you start to fill it, it will fill for about 30 seconds then stop and the lights blink twice. I cleaned the filters in the end of the hoses, are there filters in the water valve too?
I have unplugged it to try reset no change. Also when you put it on spin, it will spin for a little while then lights up and quits.
Also as soon as I plug it in all the light blink twice.
Thank you;
Leo
sidfink43
#2 Posted : Tuesday, November 3, 2009 3:02:07 PM(UTC)
sidfink43
Try to find out if there is a problem in the wiring from the power supply into the control board and then inspect the rest of the wiring. If you do not find a problem I suggest replacing the control board, not because I know that is the problem but because I cannot think of anything else which can be causing your problem.
'Here is the part.
Part number: AP4025155
alextr
#3 Posted : Friday, November 6, 2009 5:56:59 AM(UTC)
alextr
Thanks for the reply, I was thinking the encoder switch or control board.
I changed out the control board and the wife is happy now.
Leo
sidfink43
#4 Posted : Friday, November 6, 2009 6:09:11 AM(UTC)
sidfink43
Great, that makes all of us happy! Thanks for the update.
zambo
#5 Posted : Monday, September 13, 2010 9:41:43 AM(UTC)
zambo
I had the exact same problem. Every 30 seconds, it would reset itself. Bought the circuit board, and worked great!!!
I no longer have the washer, but I have the circuit board. Anyone reading this that needs one, please let me know. I'd be happy to sell it to you for half of what I got it for.
zambo69@gmail.com
