AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Replacement LED light never fully shuts off just dims
I need help. I replaced the incandescent light under the under counter microwave that lights up the stove top with a LED bulb that just dims when switched off. The bulb will switch from bright to dim but when switched off it just gets dimmer and nevers shuts off. I checked the receptacle wiring and found it to be wired properly. I assume with the incandescent bulb it still gets some power also just not enough to illuminate it. Any ideas?:confused:
Microwave Repair
