jcarrier
#1 Posted : Wednesday, August 31, 2016 8:19:15 AM(UTC)
jcarrier
I need some help please! I took apart the drain at the bottom of the dishwasher last night to get something out that had fallen in that shouldn't be in there. Found the culprit, put it all back together and thought it was good. Ran a load later that night and ended up with a puddle on the floor. I'm baffled! I put things back together exactly how I took them apart! I now have it taken down all the way to the motor shaft and as far as I can tell the seal is fine, but when I pour water in it, it still leaks out all over the floor. I just don't understand why it would all of a sudden be leaking when I put it back together the way it was! Any help would be appreciated, I would love not to have to buy a new seal.
Thank you!!!!
