My Cabrio has been having several errors including F1 and having to keep restarting it. I know that's a control board error. Sometimes LD. It shows HC at the end of the cycle. I had been restarting it but now it's shows an F40 error and will stop at the start of the cycle and will not run. It says replace the water control valve. My question is could the control board cause all these or will they be all separate repairs?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Likely rather than a whole lot of things going bad at once (coincidence) I am with you, thinking the electronic control board is going bad. Here is the part you may need Whirlpool WPW10189966 Electronic Control Board - AppliancePartsPros.com Remember if this isn't your problem we have a Buy n Try policy. For more info click the "365-Day Return" link on the parts page.
