kenwetzel
#1 Posted : Saturday, August 6, 2016 4:18:01 PM(UTC)
kenwetzel
Washer won't go into high spin at end of washing cycle. No codes show at any time. If I do error history and diagnostic test F 21 code shows under history. I replaced Drain Pump and Motor Assy. Checked drain hose and drain (ok). During diagnostic test washer goes thru test ok and does high spin ok. Tried to get service manual for this model but no one has one.
brobriffin
#2 Posted : Tuesday, August 9, 2016 5:39:36 PM(UTC)
brobriffin
Man
United States
Ken,
Its possible the the water level switch isn't reporting to the computer that the tub is empty thus allowing it to go into high speed spin.
Check to see if the water level hose is clear and not clogged. See parts number 20 & 21 in the diagram. Parts for Maytag MHWE400WW00: Top and Cabinet Parts - AppliancePartsPros.com
If the hose is clear then the water level sensor might be bad.
Whirlpool WPW10271610 Switch-Wl - AppliancePartsPros.com
kenwetzel
#3 Posted : Thursday, August 11, 2016 11:41:44 AM(UTC)
kenwetzel
Hose is clear, nothing in it. I need a service repair manual for this model, MHWE400WW00, can't locate one online or any where else, in order to test components. Thanks for the help.
brobriffin
#4 Posted : Thursday, August 11, 2016 12:51:33 PM(UTC)
brobriffin
Man
United States
Watch this video on testing a pressure switch. I know yours is a front loader and is factory set to one setting but the principle is still the same.
https://www.youtube.com/watch?v=H2MxNYWsVSw
