I have a ASW18DLS1 a/c window unit 18000 btu It will power up the control panel freezes up and won't work after a few min the only thing thing that will come on is the fan on low it won't go to a higher speed if I turn the fan up it shuts off and I can't hear the compressor kick on do I need to replace the control panel or is it something else
