lynnachester
#1 Posted : Saturday, October 31, 2009 8:21:38 AM(UTC)
lynnachester
You wrote:
It does sound like the panel (keypad), Item 1 in the "Control panel" section is going.
The tech sheet shows how to check it with a meter.
Could also be that one of the door switches is just making and pushing on the panel shuts the door enough to activate the switch.
I would try the following first in case pushing hard on the panel is moving the ribbon cable enough to get the unit going.
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Did what you suggested, I can't help thinking the door latch may be involved because all prompts work on the control panel with the exception on the start. The start will work if I open and close the door a few times and push very hard on the start. Do you still suggest replacement of the control panel or could this be the door latch??
#2 Posted : Sunday, November 1, 2009 2:44:40 AM(UTC)
Please just use POST REPLY to your thread.
Starting a new thread each time becomes too hard to keep track of things.
So the start switch checked out OK with a meter?
The connector cleaning did nothing?
I cannot say which component is gone
You could place a short across the door switches.
Remove power from the unit when doing this.
Then close it up, reapply power and if it works OK you know it is a door switch problem.
Be careful when running this as the unit thinks the door is closed so it will start up with the door open and you will get a shower.
Viking dishwasher repair (Dishwasher Repair)
by AngelaH 8/29/2023 8:48:21 AM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
Appliances Repair North York || Dishwasher Repair (Refrigerator & Freezer Repair)
by digitallab 7/8/2021 8:45:33 AM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Samsung dishwasher repair (Dishwasher Repair)
by Cougar6069 5/5/2020 6:01:38 PM(UTC)
Dishwasher repair - kitchenaid briva KIDS36EPSS0 (Dishwasher Repair)
by magicmarc 1/8/2020 5:56:50 AM(UTC)
Bosch SHU9915UC/U11 Dishwasher repair (Dishwasher Repair)
by Yariet 11/4/2019 6:35:40 AM(UTC)
Bosch dishwasher repair (Dishwasher Repair)
by 66FSTbck 10/13/2018 7:34:04 AM(UTC)
Portable Dishwasher Repair (Dishwasher Repair)
by cliff10 1/7/2018 8:53:54 AM(UTC)
by maytagman17 9/26/2015 11:33:06 AM(UTC)
Dishwasher Repair - No water (Dishwasher Repair)
by maytagman17 9/26/2015 11:25:01 AM(UTC)
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
by sun47me 11/27/2013 4:46:52 PM(UTC)
Dishwasher repair.. (Dishwasher Repair)
by mssorcha51 9/11/2013 1:30:07 PM(UTC)
Bosch dishwasher repair help (Dishwasher Repair)
by jeanettekoster 10/30/2012 1:58:10 PM(UTC)
