L. M. Wilson
#1 Posted : Saturday, October 31, 2009 7:12:40 AM(UTC)
L. M. Wilson
Have a broken belt. Have purchased new belt, but unable to remove water pump. Loosened the three screws holding pump to bracket but does not slip off drive shaft. How do I remove the water pump?
What additional information can you provide. HELP:confused:
sidfink43
#2 Posted : Saturday, October 31, 2009 5:45:13 PM(UTC)
sidfink43
It does slip off, but if there is a leak in the pump it will rust and the rust will fuse itself to the shaft, making it very difficult to get off. You just have to work at it.
If you find rust on the shaft, replace the pump as well as the belt.
