Rank:: Member
There is a clicking flapping sound from the left rear of the unit inside the cook area. It will not stop unless I flip the breaker. Then it stops for most of the day only to return after multiple uses. Is this a damper or fan that removes moisture. Is it not shutting off due to some switch or sensor???
