I was heating water, and after the typical 3 minute cycle, the plastic cup rim was hot, and water still cool, when I tried another cycle, it started smelling like something was burning up electrically, I pulled the cover and visually nothing looks bad, closer inspection of inverter board and magnetron ok, magnetron shows continuity, not shorted to case ground, upon firing up, amp gauge is wandering, and interior light is dimming, total amp draw at 17, and it seems its cycling itself down from load to 1 plus amps, I am getting heat of the upper tube case, which I noticed before, top of micro was pretty warm, in area of magnetron, im suspecting magnetron not operating correctly?
