newbob69
#1 Posted : Sunday, February 21, 2016 1:20:09 PM(UTC)
newbob69
I have a LG front loader. when in the washing process the drum will rotate clockwise but when it goes counter clockwise it makes a grinding noise and will not rotate.
Guest
#2 Posted : Friday, March 4, 2022 6:02:17 AM(UTC)
Guest
Rank: Guest
United States
I have an LG washer WM0532HW that will only spin at low speed. Medium and high speed throws CE code. Any ideas would be much appreciated.
PS, has new bearing, shock absorbers…
Edited by user Friday, March 4, 2022 6:04:24 AM(UTC)  | Reason: Typo
Guest
#3 Posted : Monday, April 24, 2023 2:47:05 PM(UTC)
Guest
Rank: Guest
United States
Wm2701 lg front load eu message
Shocks were replaced machine level seems to be ongoing with the eu code
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
LG Washer WM4270HVA/01 incomplete draining OE error (Washer Repair)
by PapawZooKeeper 6/18/2023 12:46:26 PM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
wt7600hwa lg washer (Refrigerator & Freezer Repair)
by Guest 8/19/2022 7:47:52 AM(UTC)
LG Washer Error TE (Washer Repair)
by leonthepc 7/17/2022 1:34:39 PM(UTC)
WT5270CW LG Washer (Washer Repair)
by Gerald Shaffer 7/6/2022 12:59:29 PM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
LG washer tromm (Oven Repair (including Ranges and Cooktops))
by Guest 6/18/2021 5:43:36 AM(UTC)
LG washer not powering on (Washer Repair)
by diyer2018 6/13/2021 6:29:13 PM(UTC)
lg washer power when tub is spun by hand (Washer Repair)
by robin2741 3/29/2021 10:56:54 AM(UTC)
LG Washer WT1101CW (Washer Repair)
by rsrosenberg54 3/15/2021 6:53:23 AM(UTC)
