We have a Whirlpool Cabrio that we just acquired and it had sat for a bit, so we decided we'd do a cleaning cycle first. It was filling with hot water and when it was nearly full, the mins remaining went from like 46 down to 4 and it started draining. It completely drained and then shut off. I then tried a regular cycle with nothing in it. As soon as I hit start, then it ran the drain pump for about 2 seconds, then immediately dumped water from the top for a second. Then it slowly started spinning the tub. For a min or two it turned Very slowly, then it sped up a bit. After a minute or two of that, then it stops spinning and then a few seconds later starts again with the same slow, then faster spinning. No error codes, no trying to fill with water, nothing, but slowly turning. I tried different cycles. I tried the short wash cycle, normal cycle, colors cycle and the towel/sheet cycle. They all did EXACTLY the same thing. First ran the drain pump for a couple seconds, then fill water for one second, then start the cycle of slow, then faster spinning, then stopping and starting the slow, fast spinning all over. Does Anyone know what could be up with it besides it being possessed? We don't want to have to purchase a new washer, but we don't want to throw parts at this one either. We assumed it would throw error codes if something was wrong, but it hasn't. Thanks in advance!
Alright, I downloaded the service manual for the washer and went through the diagnostic tests. The only thing I can find wrong with it thus far is that when it gets water in it, then the basket doesn't "float" which by that I mean that once it has water in it, then the agitator plate and basket are still stuck together and turn together, so if it tries to agitate, both move as one and through an overload code. Any ideas how to get them unstuck easily without taking it apart?
This looks like a pretty popular forum.... does anyone know the answer or a guess on this one? Thanks!
