Hello!
I have a frigidaire affinity that is 2 years old and it stopped going through the final spin cycle last week. I did a ton of research and found the error code is E47 so that is either the door lock or the main control board. I first replaced the door lock and it still wasn't working. Did an ohms test and it was at right about 1500 so the door lock should be good. I just replaced the main control board, reset the error code and ran a test cycle. Still no spin and the E47 code came back.
Does anyone have any ideas?? I'm about ready to throw in the towel and call a repair guy.
I would try replacing the speed/motor control board, or at least do some testing on it. Also check the wiring to and from the control unit.
If you want to try replacing the speed board and buy from this site you can return the part if it does not fix things. Also check and make sure nothing is in the pump or the internal drain hoses.
Good luck, hope this helps.
