I have a through the wall mount 220 volt Frigidare air conditioner that I cover for the winter. When I opened the unit this spring I find a time out display of .5 seconds that switches to a temp. setting of 70 degrees. None of the selection buttons work on the control. ( mode, temp, on off ect) I suspect the problem is a pc board but and unsure if it is the main board or the control / display board. Any suggestions?
