I recently wrote: The touch control panel is becoming more difficult to respond when attempting to start dishwasher. You replied for us to open the unit and clean the edge connector. This was not the issue, I do however question if the latch has something to do with the start not working, all other push areas are operational. When I open and close the latch which doesn't appear to have the same feel as in the past I can with a great amount of pressure get the unit to work. Please let me know if you think we should replace the latch/ switch or the control panel. I appreciate you help in this matter.
