burnt clutch
#1 Posted : Wednesday, April 1, 2015 8:32:54 AM(UTC)
burnt clutch
I have a Ascenta SHE4AM that will run for 4 minutes, stop or pause for 15 minutes and then repeat, running and stopping like it is stuck in a loop. The dishwasher never drains between stopping and restarting, but if I cancel the load, and then start another one, it will drain the remaining water from the prior wash. When it does drain, the water pumping out is hot. I ran the diagnostic test, but got a "no failure" result on the tests. Has anyone seen this before? Could it be a possible bad control board? Thanks in advance for your help!
-Karl
