Been noticing the pass couple days in the morning ice was wet and items not frozen like they should be. After I would close door freezer would come on and things would be fine for 24 hours. Next morning same problem again. Tonight it seems it doesnt want to come on at all. need help!! Rick
I just turned refrigerator temp setting switch to off then back to 4 , fridge came on!! What does this mean?
Here are your parts Parts for Whirlpool SS25AQXHW00 Refrigerator - AppliancePartsPros.comSounds like you have a sticking open thermostat. This is a fairly common problem. To add a little weight to this diagnosis when it happens again, instead of shutting it right off just move it up/down a bit. If the compressor fires up then I would replace the control thermostat. |
THIS FORUM IS DEAD!!!!!!! |
