kazzy
#1 Posted : Wednesday, November 19, 2014 3:58:52 PM(UTC)
kazzy
I am trying to remove the screw that is holding drive pulley and drum for my Frigidaire ATF7000FS0.
#29 of this diagram
I am using the metric hex wrench and it does not budge (even hex wrench was slightly got bent.)
From the picture for this parts, I'd need to turn counter-clock-wise.
what would i need to use/do? I did WD40, tapping with hammer, etc...
Any help is appreciated.
kazzy
kazzy attached the following image(s):
