AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Washing Machine drive pulley screw removal
I am trying to remove the screw that is holding drive pulley and drum for my Frigidaire ATF7000FS0. #29 of this diagramI am using the metric hex wrench and it does not budge (even hex wrench was slightly got bent.) From the picture for this parts, I'd need to turn counter-clock-wise. what would i need to use/do? I did WD40, tapping with hammer, etc... Any help is appreciated. kazzy kazzy attached the following image(s):
Washer Repair
