the clean light on the control panel keeps flashing. I have done a reboot & the machine runs through the full cycle & cleans the dishes. I have done this process 3 times already & it continues to work. My repair man tells me I need a new control panel. According to the Kitchen Aid Manual & what I have found on the internet, the first thing to look at is the heater or the heater coil. Is this correct? If yes, How do I remove the heater coil to check it? Thanks, Sheldon
