Model: WTW5830SW0, Serial: CT2340448. Washer drips water into drum when the washer is off. I replaced the water inlet valve assembly. Problem still persists which means the new valve assembly is leaking. There’s nothing else in line. Should I try another valve assembly or start checking voltages to the assembly? I would think that the solenoids would have the valves in the closed state with no power applied. Help!
Groups: Expert
