Wife pushed the start button the other day heard a thud and nothing moved. You can turn the drum and turn the motor axle freely by hand.
I have the dryer apart. I have tested for continuity on all thermistors.
Outlet Control and Inlet Control thermistors both read open at room temp.
If I bypass them the motor still will not start. The only thing that happens when you depress the Start button is you hear a click in the control panel and then about 10 seconds later another click in the control panel. Motor does not hum.
Any suggestions most appreciated
