Evap fan was bad. After replacing with new one it still does not kick on. I pulled out to confirm new motor was good. It is. Old motor is bad retested. However there is no power to unit. Is this controlled by board or thru a defrost circuit???
THIS FORUM IS DEAD!!!!!!! |
