Yeltnarb15
#1 Posted : Tuesday, June 3, 2014 7:14:08 PM(UTC)
Yeltnarb15
Our water dispenser and icemaker started continually dripping, so I ordered a new water inlet valve (W10408179). Be it arrived, I practiced the procedure by removing the old one, cleaning it, and reinstalling it. Both the water dispenser and ice maker worked, though they still dripped profusely. When the new one arrived, I removed the old one, installed the new one, but got nothing. No water from either water dispenser or ice maker (though I still have some ice to remove from the water line going to icemaker). Flummoxed, I reinstalled the old one, and got nothing as well. I installed the new one again, still nothing. I do get a readout when checking the resistance on the valve. Not sure what the issue is. Water valve is turned on, and fridge is cooling great. I have checked and double checked the wire connections to the valve. Thanks.
#2 Posted : Thursday, June 5, 2014 2:09:30 AM(UTC)
When you say that "Water valve is turned on" that you have checked across the door water dispense valve with a meter and you get 120 volts across it when you activated.
Sounds like there may be a problem with the water shut off valve which should be part of the house plumbing.
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
