Ignore my post of 6/01/14 Here is my problem. In normal pac motor stops when start switch is released. In extra pac it works fine ram goes down and stays until I turn the switch again just like it should. I replaced the motor but did not help. What might be causing the problem? If I switch the gray and purple wires on the limit switch the motor works fine except extra pac works just like normal pac does. It does not extra pac and ram returns up. Thanks for any help
