Hi i am in need of some expert help and hope i can get the right advice any way my washing machine which is a old top loader commercial speed queen today it started acting up and i cant figure out what to do.
What it does is it washes a load fine and seems to to start the rinse cycle but when it gets to the part to spin and drain the water it does not drain and spin the load after the wash cycle and the rinse cycle. When the spin light indicator is lit up the machine is quiet and inactive one thing i have noticed is if i want to get the spin cycle to start i can unplug the washer then plug it back in after 1 min or so and it will start the spin cycle just for 30 seconds or so then shut off again and go to the rinse or the end of the whole cycle
Things i have done is
1.Continuity test on the lid switch
2.checked all connectors under the lid
3 plugged it into a different power source
