pfoytek
#1 Posted : Wednesday, May 28, 2014 8:03:58 PM(UTC)
pfoytek
The compressor began to make a humming noise and within a day or so we noticed that the freezer was no longer getting cold. The compressor continues to run, but the condensor coil isn't getting hot. Could this be a problem with the start relay or the capacitor? What test can I perform using a multimeter to determine the condition of the compressor and start / run relay? No porting available to test the freon on this unit?
#2 Posted : Friday, May 30, 2014 3:47:41 PM(UTC)
If the compressor is vibrating and warm, the system has leaked refrigerant.
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
