donsplace
#1 Posted : Thursday, May 22, 2014 10:07:34 AM(UTC)
donsplace
We just moved and during The move, the filter got broken inside the water filter housing. The Cap is also missing. The insides of the filter fell out on my floor.
I got down on the floor and I see the remnants of a purple cylinder in the housing. I found a video on YouTube in which someone showed how to remove/replace the housing (that's how I found this site). But although I've removed the screws, I'm not able to pull the housing out nearly as far as he did in the video - - the supply tubing is just too short. And I can't get enough of grip on it to do it one-handed.
I've considered cutting the tunes and then reconnecting using addition tubing and couplers. What size tubing and couplers would I need? I remember hearing him say that you couldn't put the tubing back on wrong because they're different sizes.
TIA!
donsplace
#2 Posted : Wednesday, May 28, 2014 6:46:56 PM(UTC)
donsplace
Anyone out there have any ideas?
