nancwlr
#1 Posted : Tuesday, May 20, 2014 12:31:57 PM(UTC)
nancwlr
My Samsung RS263TDBP/XAA refrigerator is not cooling, however, the freezer works fine. Repairman came out and replaced the Main Board for $415! ouch! It still does not get cold-temp is 56. What should be my next course of action? I have a friend you helped fix his fridge and he has graciously offered to help! Any suggestions?
thank you!
barryware
#2 Posted : Wednesday, May 21, 2014 7:25:06 AM(UTC)
barryware
why not call the service company back out? They should guaranty their work.. No?
Put a thermometer in the freezer and make sure it is at least 0 to -4.
Check the damper for the fresh food section and make sure it is open.
nancwlr
#3 Posted : Wednesday, June 4, 2014 10:30:56 AM(UTC)
nancwlr
Technician replaced the evaporator-fixed the refrigerator cooling. However, the water and ice dispensers don't produce either. The motor for the icemaker runs, and when you try to get water, just a dabble comes out and then it quits. What do you suggest?
Again, thank you in advance!
