Maytag Centennial spins but wont agitate
Hello,
I have a Maytag Centennial washer model MVWC400XW0 ser C10431752 with the low profile bottom agitator. As you can see by the title, I have determined that the spin cycle is working fine, but it does not agitate. it looks like its trying as I see slight little movements in conjunction with the noise like its working but its barely making a ripple in the water. This was observed by a lid switch bypass and the lid open. Any help would be greatly appreciated as mama is not real happy about going to the laundromat.
-Mark
[QUOTE=[email removed];855958]Hello,
-Mark[/QUOTE]
MArk,
I am having the exact same problem with my Maytag MVWC400XW0 as you describe above. Did you ever find a solution to this problem?
[QUOTE=sjoyce1;876089]MArk,
I am having the exact same problem with my Maytag MVWC400XW0 as you describe above. Did you ever find a solution to this problem?[/QUOTE]
Hello, had anyone found a solution to the agitator problem?
-Mark[/QUOTE]
How do you do a lid switch bypass and the lid open?
"Hello,
-Mark"
Have you or anyone else find resolution to this as I now have the same issue.
I’m having the same issues with my Maytag bravo model #MVW655DWO Any updates to this? At first I thought the bolt holding the agitator plate was backing off. I have tightened it down but still doing the same thing. Could the shaft be stripped out at the agitator plate?
