catdaddyhale
#1 Posted : Thursday, May 15, 2014 6:13:08 PM(UTC)
catdaddyhale
was working fine set it outside for a little while with doors off. Now it will not work. I changed motor but it and the compressor will not work until you wire it up at the fan motor. If you plug it up normally it will not do anything but the light will come on.Has any body got any ideas?
#2 Posted : Friday, May 16, 2014 7:01:49 AM(UTC)
A model number may help others help you.
Which fan?
Most units have two fans a condenser/compressor fan and evaporator/freezer fan.
The condenser fan and compressor are usually wired in parallel so when one is on so should the other.
If you are referring to the condenser fan then odds are that the temperature control thermostat is not closing or you could be stuck in a defrost cycle.
