garymcgill
#1 Posted : Thursday, May 15, 2014 11:49:20 AM(UTC)
garymcgill
My kitchenaid surperba (KSRP25FNBL00) icemaker maker stopped making ice about a year ago...I pulled the refrigerator away from the wall to clean behind then moved it back and then it wouldn't work. I resolved the issue the first time by replacing the dual water valve and defrosting the line above the freezer.
1 year later.(last week)..I moved the refrigerator away from the wall again to clean and now the refrigerator has stopped making ice again....
What is causing this and what do I need to do to get ice making re-established? I've checked and none of the lines are getting kinked or stressed.
garymcgill
#2 Posted : Friday, May 16, 2014 3:46:08 PM(UTC)
garymcgill
I removed the icemaker and measured 108volts between L & N. I then put ia jumper between T & H to cycle the icemaker but the icemaker didn't run in fact the voltage between L & N would go to 0 with the jumper between T & H.
Is this a bad icemaker?
