Push Button Starts Compacting Goes To Bottom And Won't Turn Off And Go Up. Motor Will Continue To Run And Start Smelling Untile I Turn Off.i Took Apart And Can't Find Any Type Of Pressure Switch . Is There A Motor Rpm Sensor ,if So Is It A Replacable Part And What Is The Part # Thanks
