Hello need help, My freezer has suddenly started to get above freezing. Compressor runs as well as cooling fan for compressor. Fan in the back of freezer section is running as well. Temp control nobs in fridge work. Every thing sounds normal just cant get fridge/freezer bellow 43 degrees Fahrenheit. I checked the supply and return line attached to compressor one is hot and one is cool but not cold.
looking for any suggestions thanks james
Pull the freezer back panel and describe the frost pattern, partial frost, etc.
