This is a canadian model I believe. was working fine this weekend and last load the clothes are wet. Re ran the cycles to test each to see what was happening. It appears to work on all parts of the cycle, fills fine, agitates during the wash cycles, pumps and drains but won't spin. When I try it on just the spin setting it drains and then just sits there. Are there two separate belts?? Is there a reset process like the Bosch models.
Can anyone help.....Gene are you there!!? Saw lots of your advice but cant seem to find one on GE or if the belt needs changing
