Weeks after [1-yr] warranty ran out, fan got noisy. Now, a couple of months later, fan is increasing louder and refrig runs longer and longer. H-E-L-P !
I am assuming that you mean the evaporator/freezer fan. Could be that it is on it's last legs and is running slow. This will cause the fridge to run more as this fan pulls air through the evaporator coils to cool it. I would replace the fan as it is the most likely cause. Part number: AP4343697
Click on the picture for more info about it. |
THIS FORUM IS DEAD!!!!!!! |
